bmwkiller »
https://forums.nicoclub.com/bmwkiller-u34631.html
Sat Nov 26, 2005 10:41 am
I just looked at a '91 Q for sale and found that it was low on coolant. A little more than a gallon low. I pulled the oil cap and it showed all the signs of a head gasket...brown milkshake. However, the oil on the dipstick looked fine, as did the inside of the valve cover (from what I could see through the oil fill hole). I smelled nothing in the cabin from a bad heater core, nothing in the exhaust, and saw no puddles on the ground or wet areas in the engine compartment. Nothing around the water pump or any of the hoses. We filled it, ran it a little, and the level dropped again. Then we refilled it with about 2 cups of fluid, ran it again and it seemed to be ok, but I didn't have more than about 5 minutes to let it run.The car seems to run smooth, indicating no water in the cylinder, but that oil cap concerns me. Currently the car is rarely driven due to timing chain guide issues, so I'm guessing it may just be condensation on the cap from sitting, and the fact that oil being thrown around in the engine doesn't actually hit the cap, but the fluid went somewhere. Is there any Q specific problem that might explain coolant loss like this? I haven't seen any threads about head gaskets, so I'm assuming it's not any more common on these cars than any other, yes?Thanks
