WTF Wiring RB25 S1 In S14
FinkenS14
Car: 1995 Nissan 240sx S14
OK so I just got my RB25 swap into my S14 last night. Had to do the manual conversion aswell.
WEll we go to start the car and the first thing I notice is that the fuel pump does not prime. Then I go to start it and it just cranks.
Then I notice that the ECU isnt turning on, and that the relays are NOT clicking on.
Ive checked my red and black/red wires for the relays and they are good.
What the hell is going on?
Maybe a bad ground?Bad relay?Something else?
The harness did sit around for a good month, and got tossed around a few times, thats why Im thinking maybe an ECU power relay.
Any help would be great guys thanks.
Carl H
has the harness been converted?
platez808
Car: 1989 Nissan 240SX
i'm sure there are harnesses that have gone through way more than just being tossed around a couple times and siting around for a month so i wouldnt worry about that haha
are you getting power to the relays at all? should check the resistance of your grounds
FinkenS14
Ended up being a start switch wire not hooked up correctly :P
RustspecS13
Car: '74 260z and '88 300zx turbo
Nice one.
Reminds me of my friends 91 coupe he had a few months ago. Auto to manual swapped car. His speedo didn't work and after a clutch job it didn't start at all.
Ended up being 2 plugs for the starter and 2 plugs for the speed sensor. Special stuff.
Yeah he doesn't have that pos any more.
~Alex
