how does it work? (so i don't have to go look it up)ZX88 wrote:ikeya.ballers only.
Yuppp it isssbiotoxic07 wrote:i believe it is a sequential transmission. pretty much it is a semi-automatic transmission. No need for a clutch during gear change during driving. only need a clutch from a stop. Also you only can hande between 2 gears at a single moment. like a Up and Down shift. pretty effin sweet when you see it in action.
i know that nismo sells trans that are already dog cut gears but i don't know how muchwantz87 wrote:thanx for the link guys, it explained everything. it's badass but the only reason they don't use the clutch is because they modified the trans to use dog cut gears instead of helical cut. and the reason ghast says that it won't be fun on the street is because dog boxes are loud and noisy as all hell, not to mention they do not have synchros and expensive as all hell.
That sounds like compressor surge to me?wantz87 wrote:thanx for the link guys, it explained everything. it's badass but the only reason they don't use the clutch is because they modified the trans to use dog cut gears instead of helical cut. and the reason ghast says that it won't be fun on the street is because dog boxes are loud and noisy as all hell, not to mention they do not have synchros and expensive as all hell.
