r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Tue Dec 09, 2008 8:15 am
Not to thread jack, but bradt, what are you doing over the break? (16th dec - 5th jan). I have met up with Mazikowski, and I'm going to be meeting up with beans33, so how about it, we should meet up sometime and oogle each others cars.
OP, adjust the stop screw on the throttle body (the one that the little throttle cable pulley stops against). It sounds like it is holding the throttle plate slightly open causing a higher idle. I know how it works, I am running no air idle stuff, and have to adjust the TB crack angle for proper idle when the seasons change.
Of course, if you do this, there is the chance your cold idle will suck. Play around with it though, if it doesn't work out you can always adjust it back to where it was. It could also be what gabby said, with the spring being shot, or the TB housing could be all gummed up, not allowing the plate to close properly.
