WTF?!
unknown007
Car: White 1993 Q45 (G50)
This just now happened like 2mins ago from posting this i turned my ca ron went to the stroe came back it was fine.Problem is when i put it in park it was idleing at 2000rpm.I put it in drive went down in reverse went down in park back up.I tunred the car off and then back on and it was fine then.What happened?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Its call a "heat soak" when you go to the the store on a warm day and leave you car off the electrical parts inside the car heat up more because of the lack off cooling because there is no fan running.
So when you come back the RPMs rise or the car will surge which is dangerous or there will be other side effects.
unknown007
ppastos wrote:Its call a "heat soak" when you go to the the store on a warm day and leave you car off the electrical parts inside the car heat up more because of the lack off cooling because there is no fan running.
well the fan was on.i ran the car for like 45sec before i left got there and the store was close so i came back it was not even a mile away so how's it possible?
Infinitiguy19
well you got me but always, let your car warm up could be the engine or transmission being pissed at you?
unknown007
ppastos wrote:well you got me but always, let your car warm up could be the engine or transmission being pissed at you?
true that but i had to make it to Kragen to buy something before it closed but stupid employee was like we close at 7 when they close at 6.But wouldn't be anything big right as of now?
Infinitiguy19
Well if it did it once then no,
But if it does it again then yes just check for transmission codes and ECU codes maybe even TCS codes then if none of them show anything an you still have that problem then see a dealer.
unknown007
ppastos wrote:Well if it did it once then no,
Dealer= Pocket drainer
TRUE
Infinitiguy19
Do what I am going to do, Get them to do a full checkup with consult (And they better do it for 80 bucks cause that what they told me) Then just fix the problems your self but at least then you will know what the problem is.
Q45Tech pleas tell me when they say they will do a full checkup would you know what they do I mean do they do everything in the FSM or do they just go by the consult menu and just do what ever the consult lets them do?
unknown007
ppastos wrote:Do what I am going to do, Get them to do a full checkup with consult (And they better do it for 80 bucks cause that what they told me) Then just fix the problems your self but at least then you will know what the problem is.
I'll have it in mind but yeah what do they check?
qship96
Car: 1996 Infiniti Q45
Good God, just reading this hurts my eyes and head!
unknown007
qship96 wrote:Good God, just reading this hurts my eyes and head!
Mine to after reading yours hahaha my head started to hurt Monkey read Monkey do
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Sucker! The post title should have alerted you intelligible discourse was absent!
unknown007
maxnix wrote:Sucker! The post title should have alerted you intelligible discourse was absent!
You tryna call me dumb?anyways haha i still need an answer well i'll just come back to it if it happens again thanks
OnTheRoadAgain
Car: 1991 Q45
dealer charged me $129. They did not ohm test anything, just power balance.
their estimate: replace all injectors AND all coils: $3,000Their "company policy" was to suggest ALL coils and injectors.
said it would take 2 MONTHS to get the parts, because they would have to "get one at this dealer, one at that dealer" etc,. "from all over the country."
this car was dealer serviced since new (165,000 miles), at another dealer out of town.
FOR WHAT IT IS WORTH:my owner's manual (1991) says to "depress the gas pedal 1/2 way on hot re-starts"
