chrismo240sx »
https://forums.nicoclub.com/chrismo240sx-u56190.html
Mon Jan 26, 2009 5:46 am
replaced the thermostat twice so far, 1st one was autozone junk, 2nd one replced with OEM Nissan t-stat and worked fine until last night.
new water pump 3 months ago.new Mishimoto Radiator 3 months ago.
today i noticed a little coolant where my rad cap is so i checked to see if it was tight....it was but not all the way so now it is tight.Then i blead the system again and i fee like the thermostat isnt working now.
I have no heat again even after bleeding the system and thats how i know its going to overheat (when i have no heat). The resevoir is full past the max line when it starts to overheat so im thinking the t-stat isnt working again.
Can slightly overheating the motor cause a t-stat to go bad?
or what else can it be?
