WTF! starter,battery,timing,fuel,spark,ignition wires, coil, but car wont start!
91nissantwo40sx
Starter is fineBattery is fineTiming is fineFuel is fineSpark plugs fineIgnition wires fineIgnition coil fine
WAT the hell is wrong with my car!! What else is there to check? I have replaced all of this and the stupid thing is still not starting!! please guys this is some serious help. Really appreciate it for any replys.
Ekinchheng
Car: '93 Nissan 240SX Coupe
Does the car crank or when you turn the car nothing happens?
cmfireman
Car: '96 Nissan S14 SE
I tried to help last night but this cranking thing got too confusing.
What EXACTLY does your car do when you turn the ignition??
Also, have you checked all the underhood and kickpanel fuses?
91nissantwo40sx
Ekinchheng wrote:Does the car crank or when you turn the car nothing happens?
Yes the car cranks and the engine turns. The damn thing is flodded in fuel. When i took out the spark plugs the bottom of it has got gas in it. Is it suppose to be like that or is it suppose to be dry?
Modified by 91nissantwo40sx at 7:22 PM 8/27/2007
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
maybe ur distributor is in wrong. take it out and turn the motor to TDC also make sure the timing marks are lined up with the mark on the cover. then put the rotor in the distributor right before first cylinder. then put it back in.
91nissantwo40sx
cmfireman wrote:I tried to help last night but this cranking thing got too confusing.
When i turn the ignition on it makes that starter noise and the engine turns over but it doesnt seem to wanna start. I have replaced my spark plugs, ignition coil, distributor cap, distributor rotor, fuel filter,new starter, what else could be causing this problem?
A mechanic told me that i should replace my ignition module. Should i give it a shot? I was getting minimal spark until i went ahead and replaced my ignition coil. So now i seem to be getting a better spark but the car still wont run. I dont really wanna spend $100 for a set of ignition wires. I really hope thats not the problem. Any help would be great. Thanks
91nissantwo40sx
nissans13240sx wrote:maybe ur distributor is in wrong. take it out and turn the motor to TDC also make sure the timing marks are lined up with the mark on the cover. then put the rotor in the distributor right before first cylinder. then put it back in.
I had the car running for a week 1/2 straight and now it is not turning on. Also a mechanic checked and said that my timing looks like its in the right position.
Prior to this problem my car slowly died on the road. I stalled about 4 times on the road and the last time it stalled i couldnt even turn the car on anymore. After about a couple hours i would be able to turn it on again then it would die after 15 seconds just on idle. It got worst and worst and now its not even turning on at all.
Ekinchheng
Did you check all your engine wiring? Any vacuum leaks? Also check your intake vacuum, make sure it fits properly. Also is this the orignal engine or did you put a new engine in?
Soravia
Car: 2003 Audi A4 1.8T
I had the same issue. Fixed by getting the TDC on Compression Strok instead of Exhaust Stroke. That's a 180 degree off timing. Looks as if it's all right but it is not.
Also had the distributor cap and rotor bent a bit. Had to replace them.
91nissantwo40sx
Ekinchheng wrote:Did you check all your engine wiring? Any vacuum leaks? Also check your intake vacuum, make sure it fits properly. Also is this the orignal engine or did you put a new engine in?
Yes all wiring is in properly. Checked them all. Spent about 2 hours doing it. No vacuum leaks and it is the original engine. I had a mechanic rebuilt the engine for me and the car was running fine for about a week 1/2 and now it wont even start. My mechanic told me that it might be my ignition module, since they are the ones that usually go first. I also had an overheating problem for about 3 days but then i got that fixed and it still ran. then couple days later it started doing this.
Nismotouched
I had problems like this before, I checked everything like you, ended up being nothing more then a embrassing mistake on my end...haha good luck man
91nissantwo40sx
Soravia wrote:I had the same issue. Fixed by getting the TDC on Compression Strok instead of Exhaust Stroke. That's a 180 degree off timing. Looks as if it's all right but it is not.
Thats messed up. I have never heard of that before. Should i give it a shot? is it likely to be the problem? but why would it not work when the timing is in the right place? i dont understand.
My distributor cap and rotor are also replaced. The last thing is the ignition module and if that doesnt solve my problem, i have no idea what else to do.
dickie
Car: Killer Turtle
how many threads are you going to make (in the wrong section that i have to move for you) about this problem? just bump one of your other "my car doesnt start/run/etc..." threads.
