Lets ask a few questions to narrow things down (from a non SR guy view point, so excuse if I dont recognize all brand names especially aftermarket ones, or what the OEM type set-up really is for an SR, or would be if we had them here, but cooling systems are so similiar...)
Back to my "old guy" basics:
-So your rad is newer?It is aftermarket, is it an actual upgrade with proven higher btu bleed off capability than stock, or just a after-market subsitute whose capacity is unsure?-I am not a huge friend of non OEM tstats, your engine will make most power in a given window of temps anyway, setting a tstat cooler than stock, is often not helpful, also many non OEM Tsats are often not as good as OEM, and finally some are easy to install wrong way around (with predicable results)Also many just plain fail ,even when new.- You mentioned a "flex a lite" fan? Do you have a non OEM fan, maybe even subitstuted an electrical for the a stock set-up?If so electrical fans rarely equal stock, regardless what the manufacturer says.
-Finally a 50/50 mix is too thick in CA, run 70% dist water, 1 bottle redline wetter water and refill with a slicate free coolant.
I suspect your problems lie in one or a combination of the above:
Summary: OEM fan, plus OEM tstat, plus OEM radiator = proper cooling.
OEM would be, what the SR comes with in JDM.Just my back to basics 2 cents.
Fred..
