By the way, SPL sells the same thing cheaper, at $25. http://www.splparts.comgeorgegto wrote:It might be also the the clutch pivot ball, mine broke couple of months ago so u maybe have the same problem..
BTW i bought this one http://cgi.ebay.com/ebaymotors...:1123
iirc you can change the pivot ball through the hole that the arm goes through...pita but you shouldn't have to take the transmission off.duffman1278 wrote:Wow...should have changed mine when I had my engine out.
Would you prefer to buy the Gucci version instead?georgegto wrote:Yeah..but i dont think that is nismo or im wrong?
Looks like homie lost interest in fixing his problem, or maybe it just spontaneously resolved itself.91nissantwo40sx wrote:ok so my slave cylinder moved and it is not in the proper position now. When i press the clutch i get nothing and therefore i cannot shift into gear. What would cause this ? and is it okay if i try and push it back into its position? im confused
SR20DET 7psi everything stock except 3" exhaust.
