...the ball joint is not whats breaking its the shaft and connectors of poor quality metal that is not nearly strong enough to hold up to the pressure put on it. so why couldn't / didn't you go with a local manufacturer that has higher standards? it just seems that you wanted to save a buck or two to add into your profit instead of a seriously beefed up part thats of good quality? It is not just my opinion of China being junk products look at walmart they mover all of their manufacturing there because it was cheaper not because the quality was better. Im sure that the consumers of this product would have not minded paying a couple dollars more foe a better quality part and also because buying localy helped keep our workforce healthy and strong so we could be proud of the high quality we produce over China and our jobs are staying here.Racingline wrote:LOL, You do realize the "superior stock endlink" is plastic inside the ball joints right?
The shearing is an isolated incident and has been rectified. ( the pars are to rebuild the ones you already have by reusing the black shaft and discarding everything else)
as far as rears "popping off", all sets are send with 2 nuts for each bolt( 1 serrated, 1 reg). they are to be tighten and installed as supplied, ans I suspect many people are just installing the first nut. The second acts as a lock to prevent backing off of the first due to the bushings creating a "spring effect" and pushing against the installation.
The reason a nylon lock nut is not used is because when exposed to salt and contaminants the nylon actually breaks down and the nut becomes useless.
As far as China components..... quality and china have nothing in common despite your perception. Some very amazing quality parts come out of china, conversely "made in usa" does not automatically mean quality either. Quality is a matter of what your willing to pay to have it made. Just because it CAN be made cheap in china does not mean everything IS cheap from china. Most all coilover sets you see (even the "JDM quality" & "higher end" stuff is all made from the same 2 - 3 factories in china and taiwan)
This is crap, u think i care about the quality of work i produce or any of the people that work under me. I think not. I go to work to get paid. Im a manager, if im bored i work, if i dont feel like talking to people i work. Im sure most americans agree. Look at our big three, those cars stink.vonivo wrote:2. Its still just trying to make a couple dollars more while using sub-par products with low quality metal. China is known for their slave labor factory work force also...so they have no pride or care in what they are making its just the flavor of the week and it will just change next week where locally they would be proud of the products made using skilled tradesmen and knowing that it came locally would satisfy the quality standards.
so if their not proud of it at least it still came from a skilled tradesman (if you don't care about the quality of a product that you make or how it turns out then your just sad you have no self worth and pride in what you do / make, where i do take pride in my job and my duties and it shows by the quality of people we have working there)...and its made to a higher standard with higher quality pieces. Joe n Racingline don't need you to hold their hand in a forum debate...so no i wont back off as you put it.dldjros69 wrote:
i bet the people in china are afraid of getting beat or sent home with out pay. They put more time and effort in.
Back off joe and racingline
the shaft is 6061-t6 aircraft grade aluminum and made in Canada. and your still only reading the parts of my post you want to hear so im done trying to appease and justify things to you. The reputation of Racingline more than speaks for itself, as well as our dedication to the A/C communityRacingline wrote:
I have yet to see you post anything insightful on this thread, or any other for that matter. If you dont like what Racingline sells, dont buy it!vonivo wrote:
Seems to me they are working on the issue with anyone who has had a problem. What does it matter to you as it seem you don't have the part nor any issues but some personal vendetta which is causing you to be an azz.vonivo wrote:..so no i wont back off as you put it.
