Perhaps i should have been more clear. I bought the bare bottom end fully assembled with rod/crank/pistons etc still on it. No timing belt or head though. I mean you could spin the timing pulley bolt with a socket and it seems to be smooth.robbie2883 wrote:that's crazy....my only educated guess without knowing the history of the motor or being able to see into the head and block would be some kind of temporary binding in the valvetrain somewhere. bad enough to twist the timing sprocket. but odd it didn't do any damage to the belt. maybe mistimed or skipped a tooth at some point and minor interferance between pistons/valves? i dunno...i would deff check the rest of the motor over good though..that might give you some answers as to what happened
Thinking about it more i mean thats a huge impact on that thing to shear a key out like that. I'm hoping to hell that the whole thing, let alone the crank, isn't a write off.SullivanRacing06 wrote:before you cut the crank check with a maching shop to see if they can restore the snout of that crank so itll support a new woodruff/key way key ,
Yeah, that is exactly what I was referring to. Thanks for clarifying.robbie2883 wrote:your idea should work perfect....i think what's he's getting at is to mark the gear for the timing belt. there is a tooth exactly 180 degrees across from the timing mark so just a little dimple to let you know where the to line the belt up with should work great. or count the teeth. i think it's 9 teeth to the right of top dead centereither way
Evan
that's all fine and dandy but the part pictured and in question has nothing to do with the oil pump or oil pump drive. you can't even see the oil pump drive in those pictures, nor is the oil pump driven off a woodruff key.bostonS15 wrote:The RB has an known issue with the oil pump drive keyway. The oil pump drive is much larger than the driving key on the crank. Created big issues with the oilpumps failing.Nissan fixed the issue for the 1992 RB26, if i recall correctly. So the RB30 had the same issue. When i built my engine, we made a crank collar for the oilpump drive.
So, with this useless fact aside, it is possible that the oil pump failed in the past or the owner went in to fix the issue and reassembled the pulley incorrectly.
St240 - you gota redo the oilpump drive or it will come apart under good load. Just a thought.
ThanksYury
