Postby
Yellow4g63 »
https://forums.nicoclub.com/yellow4g63-u4416.htmlSun Feb 02, 2014 5:02 am
I'm grinding in 5th gear! the only time it won't grind is in low rpm but if I'm pulling though the gears and go to 5th I'm greeted with a nice GRIND!!!!!!. I have that Amsoil transmission fluid in it right now.
Postby
RRRRB »
https://forums.nicoclub.com/rrrrb-u185303.htmlSun Feb 02, 2014 9:38 am
One of the insert springs probably came out. you can replace them without taking the sliders off, its probably attached to the magnet on the drain plug
Postby
Yellow4g63 »
https://forums.nicoclub.com/yellow4g63-u4416.htmlSun Feb 02, 2014 4:36 pm
Fuk if I'm doing that ill prob be changing other s*** too. I'll add that to my list of s*** that I might do lol. Looks like I'm fixing the RB20 trans 1st since I don't want the down time.
