WTF?!?! Q45 caliperts not bolting up to my S14 brackets
first time s14 owner
Car: 1997 Pathfinder SE 4x4
Did I get some special Q calipers that are difefrent or what!??!I'm mega-screwed, as I'm doing a 5 lug conversion at the same time, so my car is off the ground and wheel and hub-less. My HOA won't like that too much! And it's my only car right now!!
see...28mm Q calipers
not even close to matching up!! S14 bracket on the left, Q caliper on the right!
JeromeS13
Car: 2008 Subaru Impreza STI
I'm not an expert on this brake upgrade, but wouldn't you need the Q45 bracket as well?
-Jerome
JeromeS13 wrote:I'm not an expert on this brake upgrade, but wouldn't you need the Q45 bracket as well?
-Jerome
NO, 90-96 Q calipers are supposed to be direct bolt up...
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
you need the brackets that bolt to the knuckles. think about it --- q45 calipers are much larger than single piston S13/14 calipers. therefore, you need the caliper bracket from the Q.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
The Q torque member right?!
AmoebAssassin
Car: 1991 Base fastback 5spd, black
You need the Q torque member/bracket and caliper.
The S13 and Q torque members share the same spindle mount bolt spacing, but the torque members themselves are NOT the same.
thanks! I figured as much, even though taht contradicts everything I've read on here. People selling them, always sell just the calipers and say you don't need the brackets.... So, the silver bracket from my car is what I need to grab from the Q, correct?
jdm_master_X
yessir.
positron1
first time s14 owner wrote:People selling them, always sell just the calipers and say you don't need the brackets....
Yeah, all the time.
kamikazestorm420
you need the bracket in order to mount them in. so yes find that piece
