FarFetched »
https://forums.nicoclub.com/farfetched-u25415.html
Tue May 31, 2005 7:00 pm
I ment plenum R+R is 1-2 day job w/o proper set up! Plus you gotta get a few gaskets to plenum R+R!The way I did it, it took me about 4 hrs with taking few brakes. Make sure you have the water hose that is under air runners, you will need to cut it to get it off. I don't remember size but NAPA carries hoses of that size. Cut it in half, take it to NAPA and you'll be all set. Reuse all hose clamps, otherwize you'll end up with leaky hose JAPANISE cars have BETTER technology when it comes down to details such hose clamps and the like!I ran it today on a "Red Brick" Snap-On scanner in Generic OBD-II mode no DTC's or abnormal data. O2 (upstream) seemed to be a bit (tiny bit) lazy. I will deal with them later. Get spark plugs replaced the same time. Cheers1
