Blown240sx wrote:then use the cap to slowly draw them in tightening a rotation per screw alternating until it bottoms out.I used OEM rings.
DON'T do that!
You have to "POP" the injector inside.
I used the write up that "AZHitman" had and what you do is get a socket that fits inside the small hole of the injectors and you get a ratchet attached to it and push down on the ratchet until you hear it pop and that's when it's in all the way.
If you have done this and the problem persist than I highly suggest looking into getting new injectors. It seems to be that your injector has a very small piece thats cutting them, probably something that's not obvious.
I had a leaky injector for awhile with my old injectors and replaced the orings twice than I just got rid of them and bought new ones from DW and it's been fine since then.
