wtf just happened!!!!
mastakilla08
Car: 1992 hatch, 1989 piggy coupe, 1991 coupe silv.
OK, Driving my s13 yesterday with my pal in the passenger seat.. im behind a gayass vr6 jetta so i decide to do a little smoke show , so i rev up drop the clutch booom im spinin all through second gear, so then i shift to 3rd and im cruisin along and i goto push in my clutch and wow no pedal at all goes straight to the floor and stays there , so i figure its the master but its a brand new nismo i just put it on 3 days prior, so i do some tests not it! then i look at the slave and its perminatly stuck out and i can move it with my fingers?? so ive decided thats the problem cause i did they bypass were the line hooks direct into the slave and it might be to much for it??
Any input would be helpful im starting to lose faith!!
ashibah83
Car: 93 SUPA BLACK COUPE
ok...... DONT DRIVE LIKE A d!ck!!!!!!!!!!! you deserve it and im not going to help you, people like you are the reason why our cars get a bad rap....d!ck!!
1KleenS13
^^^ wow, talk about a buzzkill.
I'll try to help you out there lil' slugger. Check the rubber line going to the slave. It could have failed internally and is acting like a 1-way check valve now.
Vegascorbin
Car: 1990 240sx dirt track race car
ashibah83 wrote:ok...... DONT DRIVE LIKE A d!ck!!!!!!!!!!! you deserve it and im not going to help you, people like you are the reason why our cars get a bad rap....d!ck!!
I guess we know who was driving the Jetta......
Sounds like the slave failed. Could be it couldn't take the higher pressure of the fully working new master.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Is your clutch engaged at the moment? It could be that the pivot ball in the transmission broke and now there is nothing for the fork to push against.
Klits562
Car: white s13 coupe
Vegascorbin
the converted wrote:Is your clutch engaged at the moment? It could be that the pivot ball in the transmission broke and now there is nothing for the fork to push against.
Good Thought. I did not think of that option.
mastakilla08
ya that actually makes sense from what im looking at... cause i put a new slave on and when its fully engaged it doesnt disengage the clutch at all i mean not even a little.... is that a pretty common thing for that fork pivot to break?
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
I'm not aware of it being common at all. I have a twin disk in the track car on the stock pivot, and haven't had any issues.
