onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Oct 31, 2008 4:20 pm
given that no one on this board knows the true condition of either your car or the cluster, here is the only thing I can think of to do:
- try the cluster in someone else's car
- if it works then, then there is something wrong w/ your car - i.e. speed sensor or some other electrical issue
- if it has the same problem, there you go.
If you swapped it whole - i.e. cluster + correct tach + cluster sub harness that goes from cluster -> main dash harness, there isn't much that can go wrong.
