wtf is wrong
mdubc405
Car: white 1989 240sx coupe w/ca18det(t3/t4 .50trim)
so i have a ka24de-t, ran fine for awhile then it sat for about two weeks, drove it to a body shop to have a minor facelift and some new paint, ran fine, out of left field it won't start and gas is pouring out of the exhaust manifold, changed plugs, cleared the cylinders(in case of severe flooding) and had the injectors flow tested, nothing wrong with them, but its doing the same thing, any ideas?
WDRacing
No spark...
Riubens
Car: ka-t 240 and 99 Q45 t
looks like some body in the body shop went for a little joy ride.
NateDogg
Could be one of the injector signal wires is shorted out causing full open condition.
mdubc405
well i changed the plugs, the plug wires are all good, i'll check the other wires though, thanks for the suggestions!
WDRacing
You can change the parts all day, if they aren't getting power you're just swapping out perfectly good items for no reason.
WD
Chezedik
Car: 1991 Nissan 240sx
I agree! I would talk to their boss, because there is no good reason that a prefectly running car would leave dripping fuel.
mdubc405
well i checked the power and its getting power fine, this is starting to piss me off
WDRacing
Well, to run you need fuel, air and spark. Troubleshoot each system all the way through. Obviosuly you have air, unless the IACV is stuck shut and the throttle won't open. So that leaves fuel and spark.
WD
coolbone28
^don't forget compression too
Florida240sx
Won't start... distributor bad? not igniting fuel... how old is it...
mdubc405
well it starts, starts out on all cylinders then goes to 3, then 2, then back to 3, and smoke is everywhere, coming from under the hood and exhaust, oil is coming out of the return line, the turbo side, which means there must be something blocking it, because there is no pressure after the turbo
Chezedik
Did they do any welding on your car at the body shop?
mdubc405
nope
Chezedik
Have you done a compression check to verify that they weren't just joyriding and blow the engine? Check all your body grounds?
WDRacing
Drop off a running car, pic up one thats AFU...really simple deduction. Take it back and have they pay for everything that is wrong. You may be screwed for having waited so long. If you need help filing a grievance with the proper authorities and bureau's let me know. I can point you in the right direction.
WD
Chezedik
Def, that is the way I see it. Especially since it is a body shop, if it were a speed shop I might tell you tough titties. A mechanics shop, well, shame on them if it leaves without running. But a BODY SHOP!?!?! You need to talk to someone.
