that really helps, thanksexhsturbine wrote:all of this is set on compression stroke (obviously)( - X - - - - ) x= tdc, set on the "needle" for mechanical timing. ( - - - - X - ) x= 15* before tdc, mark with paint or chalk for ignition timing
the best way to set the crankshaft timing to the camshaft, is with the colored links on the chain. then you insert the CAS and 240life is correct when installing the CAS........ on the CAS "shaft" line the "dashed mark" up with the "circle" on the right, then when you insert it into the exh cam gear splines it will move to the left "circle". if its inserted dead nuts your bolt holes will be right in the middle of the slots on the CAS. of course all of this is outlined in the fsm, should you run into any snags. good luck.
Modified by exhsturbine at 12:31 AM 9/19/2008
well i took a spark plug out and put a long screw driver in the hole so it rested on top of the piston then i moved the crank till the piston was at TDC on the compression stroke, then i matched up the CAS dots and put it in, then the car started...HOORAY ^_^, it doesn't backfire at high rpms so far but it gurgles if i take my foot off the gas and dont take it out of gear, it gurgles like a mother FU&$^R, but its all good i take it out of gear when i slow down and coast in anyways, i dotn really like to downshift either, im guessing that might have to do with those forged 9:1 pistons i have in there maybe ?Hijacker wrote:The likelihood of getting the colored links to match up on the cams is slim to none. Just set the crank to TDC, and if your cam gears have their mating marks pointing correctly (10 o'clock intake/12-1 o'clock exhaust), you're good to go.
STFU noob240_SeX wrote:no way...its totally safe to run 9:1 with no tunning, maybe you should carnk your boost too
i might have, but have been an @sshole for a while, so let me rephrase that240_SeX wrote:you have asked 130 newb questions, i have asked none...
yes sirvanquish2 wrote:easy there killer....calm down
240_SeX wrote:you can suggest what you please, but i will post whatever i need to know if i can't find the answer the first time. just leave it at thatmigsk8 wrote:i might have, but have been an @sshole for a while, so let me rephrase that
STFU @$$HOLE[/QUOTE
Again you can call me all the names you like, all i do is tell you that your stupid ideads are well, stupid. If you cannot stand up the critisizm then i dont suggest posting thread after thread of questions that can very eaisly be answered by a few seconds of searching...
