LexusMaster »
https://forums.nicoclub.com/lexusmaster-u82186.html
Sun Nov 25, 2007 2:02 pm
I don't know about Infinitys but on toyota and lexus, there is a reset button for the tire light that's underneath the driver side dash. The light is supposed to come on when the psi in any of the 5 tires (spare included) goes below the minimum set threshold. You can set that for what ever you want, all you have to do is put the amount of psi you want in all your tires and and take away %15. so if you set your psi at 40 your min threshold would be 34psi. That's how most TPM systems work. If you don't want the light to ever come on unless you really have low tire psi, just inflate all your tires to 10 psi and set the button, afterwards inflate your tires to whatever you desire like 35psi, now your TPM won't come on unless one of your tires hit 8.5 psi.
FYI
The TPM sensora operate with a lithium ion battery, and when they go out, u need to replace them.
