WTF is this liquid in my intake manifold?
Yoda's Master
Car: 2012 M56
2009 370z
I couldn't delay replacing the starter any longer and found some green liquid in my manifold when i started taking it apart. Is that normal? It's not coolant and my intake tubes are dry. :confused: :confused: :confused:
I wonder if it's a by product of using CRC GDI Intake Valve Cleaner, which i must say is impressive. I'll post pics later.
Ilya
First guess would be coolant but you already took that out the equation. Interested on what you determine!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Ilya wrote:
Mon Feb 14, 2022 8:09 am
Me too. If it isn't coolant, then what? There isn't much on an automobile that's Venusian-colored.
DenisMcG
Car: 2009 Infiniti FX50
What makes you think it isn't coolant? If you have any of the CRC stuff left, spray some into a small glass container and check the colour.
Yoda's Master
Car: 2012 M56
2009 370z
DenisMcG wrote:
Mon Feb 14, 2022 2:05 pm
Because my coolant is blue. I don’t have any of the crc stuff left, but it was clear when I sprayed it.
DenisMcG
That answers that. I checked online and it appears that the CRC is clear, but it might be green when it puddles. Are you able to get a sample and see if it smells petroleum based. I do have to say that the intake looks super clean.
Yoda's Master
Car: 2012 M56
2009 370z
DenisMcG wrote:
Mon Feb 14, 2022 3:44 pm
I’ll check when I get a chance, but my intake valves look cherry after spraying this about 2 months ago.
Yoda's Master
Car: 2012 M56
2009 370z
So it's oil. I have no idea why it looks green. It's only green in the cavity, the residual oil in the runners part are still normal oil color. Idk why it's green, but whatever.
Ps. Don't use long needle pliers to pull out the shop towel used to soak up the oil. Oily handles are slippery.
VStar650CL
Technical Expert
Yoda's Master wrote:
Mon Feb 14, 2022 10:37 pm
That's plain weird.
DenisMcG
I wonder if the oil mixed with the CRC gave it a green tint.
VStar650CL
Technical Expert
I will not use green oil or ham,
I will not use them, Sam I am.
:lolling:
madmanpauly
Car: 2011 Infiniti M56S
The only other green fluid I'm aware of is in the A/C - it uses a green dye to find leaks. But I don't have any idea how that would end up in your manifold?!?!
macgiver
Oil mixed with blue coolant and also possibly with the CRC , you got that GREEN color change . Experiment mixing the above in several different ways may prove this ?? Like the science teacher's experiment - Color change upon mixing one or more chemicals.
Otherwise.........................Blame it on Venusians :confused: ......... :lolling:
Yoda's Master
Car: 2012 M56
2009 370z
Mixture of that crc cleaner and oil from the pvc is the only thing i can think of. Not planning on spending another $17 for a can of crc just to try mixing it with oil.
macgiver
10-4 Just some " Weird Science " go'in on there ........ :spitout: ..... :rotflmao ....... :facepalm:
