deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Tue Jan 22, 2008 1:46 pm
A large easy-out covered with grease should do the trick.
Go to your local autoparts or tool store and explain to them what happened, they should be able to help select an easy out bit in a size that will work.
Easy out tool looks something like that, you wont need to drill because you should already have a hole in the middle of the adapter you have stuck into your threads.
I recommend this because from what I gather you have busted the hex-head off of the adapter. DONT FORGET TO COVER THE BIT WITH GREASE! And for future reference, these compression adapters dont need to be tighter than finger tight, they should have an o-ring to help the seal, and even if not, the threads arent going to let a whole lot of compression past and skew your results. Remember, lefty-loosy righty-tighty.
