evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Jul 17, 2007 7:27 am
183k on the clock when was the last timng belt put on? if you don't know plan on spending $500 for the parts to do the job and if you have to have it done double that figure
back to problem solving, check the timing, check idle vacume, if your timing is off or you have little to no vacume, do a compression test, you might have sheared a tooth off the timing belt and taht could have damaged some valves
