c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Sat Jun 10, 2006 4:48 pm
So I was driving my car around tonight... everything was cool, messing with the manual boost controller I have trying to set it around 12psi. Well, all of a sudden, my car sounded like a WRX and felt like it was on 3 cylinders. Now, this happened about a month ago too out of nowhere. I just shut the car off, unplugged the negative terminal to reset the ECU, and then all is good again. I tried just shutting her down and starting back up, but that didn't do it. I am running very rich (10.0:1 AFR under boost). You think one of the cylinders could have flooded causing no spark or something? Or even worse, ANOTHER bad ignitor? Any ideas?
