longhornsqx4 »
https://forums.nicoclub.com/longhornsqx4-u124502.html
Mon Nov 23, 2009 3:10 am
I might as well state the problem first, my car wont idle and seems to be GUZZLING gas. The car is a little rough on idle on cold start, when it gets warm it wont idle, its a smooth idle once warm, but then it just goes from 800 rpm when it wants and DIES, motor turns off, you can keep it going by giving it gas, then when it wants, dies again.
I also noticed that I burned $20 worth of gas in 25miles!! Going from one town to another and back, almost a quarter tank.... crazy
Heres what I did to aparently make this happen, I modified the cold air intake, I simply unhooked the battery, pulled the entire intake off, its HUGE I simply disconnected the piece after the MAF sensor and added my own 3" pipe about 10" long and put a high flow cone filter on the end of it. I also deleted the 1 small elbow and the box that went under the intake, I assumed they were for sound, as they went knowwhere.
So I did infact disconect the MAF sensor, and its installed back the right way, connection is good, and I disconnected the battery for almost a day. But why would it make my car run like this?? I cleared the codes, and none came back up on a 5 min drive, but the car still wont idle
The 2 codes I pulled wereP0100 : Mass or Volume Circuit Air Flow MalfunctionP1110: I COULD NOT FIND WHAT THIS CODE MEANT
Id love to get any help I can, appreciate it
