wtf happend to my tachometer
enzo 240
ok well the other day my ground came off of the frame and it caused some **** to fry but now thats fixed. but now my tach doesnt work and when i turn the head lights on the cluster lights dont turn on.. i checked all my fuses and i cant find out whats wrong.. does any one know???
email me at [email protected] or aim vincenzino115
ChavezSA
Car: R/C,drifting, R/C drifting, GT3 drifting, reading drifting mags, watching drifting vids...
I have a similar problem. My gauge cluster doesn't illuminate when you turn the headlights on. I tried swapping in a digital cluster one day, and the digital cluster illuminuated, so it leads me to believe there is a bad ground in the original sub harness that connects the cluster to the main harness.
Just a guess though. Haven't gotten my hands on a replacement sub harness to test my theory.
enzo 240
do u know where they conect to eachother???
enzo 240
does any one have the wire diagram for a 95 nissan 240sx??? its not my gauges i cheked! it had to b the wiring
Modified by enzo 240 at 3:28 AM 2/18/2005
enzo 240
ttt
ChavezSA
I'm not sure how it is in a S14...In my S13, there's a sub harness that's right behind the cluster, that connects the cluster to the main harness. In the S13, it's a little over a foot long, and it can disconnect from either the cluster and the main harness-it's modular. I imagine the S14 is a similar setup.
enzo 240
i'v tried to go threw it but it gos all the way down threw the dash and i cant find it
slipnfall
Car: '06 D40
[On the S13 at least], the illumination for the cluster is controlled by the TCU(timing control unit), little white box under the D/S fuse box. The wires are easier to get to there than on the harness. There's a testing procedure in the FSM. If that's OK, just check that those signals are getting to the rear cluster connector. It's pretty unlikely that you have an open or a short in the harness itself. Also don't rule out bulbs. :-)
-Slip
