Damn test these things suck. I just did my e-test for the third time and failed. The first time, I failed for nox, (the 25mph test) by 700 points. OK, I changed my 12 year old cat and tested the egr valve. Egr test good. Second test and FAILED big time for nox. Both 15mph and 25mph test failed this time by a thousand points. Trouble shot my egr system. Chked bpt, changed egr soleniod, cleaned contacts on harness and changed vacc lines. Hell I fixed my idle problem while doing all this
. Test number three, FAILED!!! Same results, numbers were bit better but still failed. I was wondering how the hell I can change my cat and the crap gets worse? My real question is, Does anyone know or can find out, what the vaccum reading is before the bpt valve when your going 1500 and 2500 rpm? I'm getting close to nothing. I know the egr valve opens at 2 hgs of pressure. That may be my prob., not enough press. If anyone can help that would be great. This sh#t is pissin me off.
