naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Mon Sep 18, 2006 5:29 am
That is a load of bull****. They should design their hubs to have exactly the same bore size as oem nissan bore (63.1 mm I believe). If you end up having to machine something, that's pretty bad.
Make sure there are no burrs or lips on the edge or the hub or wheel bore. Maybe smooth any edges over with some 400 grit?
Edit: I just saw that you ar fitting enkeis, which have a 73mm bore. So these aftermarket hubs are designed in such a way that you can only fit aftermarket wheels? Lame. Either way, they should at the very LEAST be able to accomodate those enkeis.
