Wtf engine mount bracket
MicTheHuman
Car: 2011 Infiniti M37
Does anyone know the part number for this motor mount bracket ... m37X 2011 , FML
MicTheHuman
Can’t get the imgur image to load but it’s the front driver side motor mount bracket for the awd
MicTheHuman
https://imgur.com/a/CKLY1pQ
Can not figure out how to embed it correctly, so here is the link...
cliffyk
Car: 2012 Infiniti M37 Premium Pkg
armybrat
Car: 2012 M56x with Tech Package (sold)
Custom 2-1/2" X-pipe exhaust with OEM sport mufflers
HPS intake hoses
Uprev tune
I believe this is the part you need...probably get it cheaper on Ebay by searching the part number.
MicTheHuman
Thank you!!!any idea what part# 11375 on that diagram is? I don’t have whatever that is supposed to be
armybrat
HPS intake hoses
Uprev tune
MicTheHuman wrote:
Mon Sep 17, 2018 9:38 pm
According to the schematic, that is the dynamic assembly. Part 11375JK510, $226.55. Once again, you can probably get that cheaper elsewhere. You probably lost it along with the bolt and washer when the bracket broke. If you look at the passenger side you'll see how it fits together. The bracket is different on that side but the insulators and dynamic assemblies are the same for both sides.
Website where this info came from:
https://parts.infinitiusa.com/?siteid=15
Type in your car info, and click go without typing anything in the search field. Click the open vehicle attributes and select your trim package. Then scroll through the list on the left and narrow it down to where you need to be.
You must've hit a pothole or something to break that bracket. Those don't usually need to be replaced. I would have a look underneath and make sure there's no other damage, as well as check alignment. Hope this helps!
