TeKKiE wrote:
Yep, that's what I meant I'll try that today. If the actuators are working fine, you're saying that the locks on the door panels themselves are what's binding?
I noticed this morning it was cold out, and they operated just fine. I'm wondering if the heat has something to do with making the locks stick...
Yes, pretty much. I have seen this as a culprit several times. Heat expands certain things, and it may just be miniscule enough to make it bind. So yes, try it with the door panels removed and see if it opens/closes easier.
Over time actuators do wear down, but certainly shouldn't that fast. Keep me posted and I am sure we can work out the problem. Good luck,Jonny
