WTF are these holes in my manifold?
node
What are these tiny little ports just opposite the injector holes in my KA24DE intake manifold? at first I thought they were cold start assist but now I have no idea EGR maybe?
Thanks
Touchdown038
Car: Computers, cars, sports
They're speed holes! :)
Seriously though, I have no idea. A picture without a flash might help more too.
alex7542
Car: Racing and high horsepower
Hey if im not wrong. thats the vacuum port that goes connected to the pipe on the bootom of the intake manifold. if u look under there a medal pipe with 4 hoses connected to it. thats all vacuum. i belive thats the hole. and jsut so u know i removed those vacuums in my ka. so maybe u can do the same. just block the hoses off with big screws.
node
thanks thats what I wanted to know. Im in the process or removing the emissions and and that stupid set of butterflys. Im just going to use one or two vacume outlets from the back of the mani and run those to a distribution block.
alex7542
ok/ well i took mine completly off. and that i know off i didnt have any vacuum probvlems with my motor. but my motor is a completly different issue. i threw a rod bearing so w/e but vacuum has nothing to do wit it
pr240sx
Those are the PCV vaccum portsThe run to a tube under the upper manifold and then to the PCV valve.Dunno why Nissan used 4 ports for a PCV instead of a single line to the plenum.I dont recommend that you plug or modify that critical part of your engine.I tried to use bigger rubber line with a distribution block for vaccum and the car runs like crap and blew a seal. Also, oily deposits rapidly accumulated on the intake (via blowby hose)Went back to stock.Clean those suckers really well, even try to slightly smooth the holes
node
Nahh Im going with NO emissions whatsoever so I will be pluging them and venting the crank to atmo. BTW I alredy run without PCV and it runs fine
pr240sx
Or you can use a exhaust ventilationIts a check valve soldered on the exhaust stream so engine blowby get sucked by the exhaust pulses.Check for it on Summititem MRG-6002
node
that sounds cool too ill check that out
Asleep Altima
Car: Turbo Altima, SR'd S13
what butterflies and where are they located? ive heard talk of them, but ive never seen them...
robertwb70
Car: 72 datsun truck=PL-521/on 85 frame Z-24eng+cam+ported+weber38DGAS
pr240sx wrote:Or you can use a exhaust ventilationIts a check valve soldered on the exhaust stream so engine blowby get sucked by the exhaust pulses.Check for it on Summititem MRG-6002
that only works with open exhaust and relatively high RPMslike drag racing-where you'll see lots of them
will not work with muffler or long/convoluted exhaust pipes or at typical street car RPMs
robertwb70
Asleep Altima wrote:what butterflies and where are they located? ive heard talk of them, but ive never seen them...
the butterflies are mounted in the intake manifold-just before the head and only on the 91/92 years IIRC
Asleep Altima
ahhh, thank you, didnt know that... :)what are their purpose?
robertwb70
they are supposed to increase low RPM power by increasing velocity and swirl of the incoming air-it's sort of a crutch to make up for the disadvantages of 4 valves per cylinder(reduced low RPM power) there are many ways manufacturers try to accomplish this since low RPM power is so precious in 4 cylinderslike long tuned intake runners(like our motors and older chevy TPI systems) valves that restrict some of the runner area(the valves we are talking about-similarly the old corvette ZR-1 had 2 runners per cylinder for the same effect) and of course other are doing it with variable valve timing(like hondas VTEC)
nissan eleminated these valves in later engines-and when they did they also reduced the cam duration to get back to what they considered acceptable low RPM power-I think they might have made the intake runners a little smaller also-but I've never had one of the newer(non valved) intakes to check
everythings a trade off so they size the runners/valves/cams for the power they want and then try some clever ways to minimize the down sides
Asleep Altima
kewl, thanks for the info. :)
node
robertwb70 wrote:the butterflies are mounted in the intake manifold-just before the head and only on the 91/92 years IIRC
Uhhh so my 95 engine doesent have them, hmmm mabe I should have that intake ported instead.
