wtf another busted exhaust manifold stud!
xjon
Car: 99XJ, 93 240coupe
I removed the exhaust manifold to fix one of the studs since it was torn off when I received the engine. So I fixed it with a perma-coil thread repair kit. ordered a gasket. now I was placing the manifold back on and I got the bolts snug. I used the torque wrench at 15lbs so it will all be uniform to begin with and this other stud just snapped (more like melted off, like butter).
If I can pick up the engine I would have a hole in the garage wall about the size of the engine.
What's the deal with that?
Also, I was going to tighten it to 33-35 ft-lbs. Is that about right?
Bluefire
From surfin SDU and Skylines Australia, it seems this is a common problem... either the heat weakens the stud and or the stud might have been overtorqued before... Anyways I think about 30 ft-lbs should be fine
-Bluefire
xjon
should I just replace all of them?
Joe
no, just replace the ones that break
those studs are in a horribly hostile enviornment, they break constantly.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
xjon wrote:I removed the exhaust manifold to fix one of the studs since it was torn off when I received the engine. So I fixed it with a perma-coil thread repair kit. ordered a gasket. now I was placing the manifold back on and I got the bolts snug. I used the torque wrench at 15lbs so it will all be uniform to begin with and this other stud just snapped (more like melted off, like butter).
Do you know the part # of the exhaust manifold gasket? is it the same as the rB20?
xjon
I don't know if it's the same as the rb20. I ordered it from rbmotoring.com . the exhaust alone is $64. I also ordered the intake manifold gasket $25 since I thought I would remove that too. I'll save it for the future greddy intake.
rbmotoring would know and sells gasket separately and in kits.# 626-961-9213
sorry but on the invoice it just says "rb25det exhaust manifold gasket" no specific part #.
xjon
Allright, the bad boy's out! Now if only I can find the same stud. I can't find the washers that came with the engine. I was at the dealers today to look for the thick washers but all they have are 6mm. the rb is 8mm. So hopefully I can find the correct stud.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
YOU MAY WANT TO GET A QUALITY STAINLESS STUD SET FROM ARP, TELL THEM THE BOLT DIMENSIONS AND ITS AREA OF USE AND THEY WILL GET YOU SOMETHING THAT WILL LAST AND BE STRONG.
xjon
I just changed all of them with nissan oem part # 14064-2w600 studs $1.50. Slightly shorter but works. Didn't use the big washers anymore. Used a nut with a wide end that's suppose to take the heat just fine. I believe it's for a pathfinder exhaust manifold nut which is $1.10 part # 14094-31u00. The mechanic told me that they don't use the washers anymore when they use the nut with the flange. Torqued it to 30 ft lbs.
BTW I went to 6-7 parts stores and couldn't find a similar stud. Only one had some but they were really short. I looked hard since I was told by a dealer "off the top of his head" $5 per stud. Had no clue what he was talking about. Hate them.
M10 X 1.25 both ends
