eazye2000 wrote:I did something that may or may not apply to you.
But when I replaced my defective thermostat, I drilled 8x 1/16" holes around the edge so that water and air could still get through, just not alot. This helped when I had to bleed the air out of the system, and it actually warms up faster.
To each his own. And that's my $.02
Well at 130k it's good to replace the water pump anyways.
But about the air holes on the T-Stat it seems like it's almost a must on the KA. Every friend I eve had that replaced a T-Stat with no holes had weird problems like that.
As soon as we got one and drilled at least on hole and place it at 12'oclock, it started working fine. KA's are very picky about air being in the system.
I would also replace both temp sensors, especially the one that goes to the ECU. For some reason those like to go bad too. Although you really don't hear about them cause the problems they cause usually make people think it's something way worse.
