WTF 91 TT - Clock, Wipers, AC, Mirror & Lighter OUT!
Peabody
Car: 67 Pontiac GTO and coming soon 91 Z32 TT
Wow this is very odd.
Went to take my car out today and when I plugged my phone in the lighter it did not work. Anyway just started driving and noticed the clock is also out. Checked the wipers and AC panel and they do not work. I checked the fuses inside the car and they are fine. I just went to the car to try again and when I turned the key my wipers came on and they stopped in the middle of the window (I had the switch on and did not know it). Now my beautiful 22,000 mile Z has its wipers stuck in the middle of the window. I was going to check to see if any fuses under the hood control this CRAZY problem.
ANY SUGGESTIONS!
THANKS
Peabody
Just checked the fuses that I can under the hood and they are fine.
I do not know how to check the Large fuses under the hood.
This is not good!
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Those are fusible links, and the checking procedure is in the FSM. Definitely get familiar with the FSM as it will help you in ways you never thought possible.
http://www.nicoclub.com/FSM/300zx/
There are two fuse boxes under the hood, one by the battery and one on the fender.
Moving to Tech forum as well. Good luck!
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Have you tested your battery yet with a multi-meter? It kinda sounds like a bad alternator/battery issue
300zxstanced
Car: 1992 300zx tt
2008 Ram Hemi
2008 X5 4.8
2007 Camry
2007 Hayabusa
Please check your interior fuse box, its on the driver side, near the dead pedal, one the left.
Peabody
I checked all of the fuses in the fuse box and they are good. Also all fuses under the hood are good. Do not know how to check the large ones under the hood.
I will take it in to a local shop to see what they come up with. I googled my problems and found a few posts that are exactly like my issues and they have no replies. Someone did say it could be a relay behind the fuse box and another saying the ignition switch.
My console has no power - clock, power mirrors, sport/touring switch, lighter & rear window defrost
My AC pod also - All AC controls, rear wiper & front wiper
All this just went out on a car with only 22,000 miles!
nexus08
Car: 1990 300ZX NA
Peabody wrote: All this just went out on a car with only 22,000 miles!
Maybe only 22,000 miles, but lots of years. The time works against electronics as much or more than miles do.
Hopefully you find the problem soon.
Peabody
I found a guy pretty knowledgeable today.
I will let you guys know the results.
THANKS FOR THE HELP!
300zxstanced
Car: 1992 300zx tt
2008 Ram Hemi
2008 X5 4.8
2007 Camry
2007 Hayabusa
Just dont come back and say its the fuse on the back of the radio. Lol
twinturbozxtacy
Car: 91 tt
a car with such low mileage has been sitting for a long long time... i had mouse problems when my car sat for 4 months, might have a chewed through wire. just food for though.
Peabody
It was The Ignition Relay behind the fuse box.
$29.99 part and $180 labor
I should have fixed it myself.
I took the 2 screws holding the fuse box out and tried to get the box out but was scared I would screw
something up. I should have just took all the connections off the box and try to do it. I never messed with wires/connections like that so I just put it all back together and took it to a shop.
After $228.36 I should have TRIED HARDER!
twinturbozxtacy
Car: 91 tt
lol you got off easy! the z usually rails you pretty hard when you bring her in to a shop. glad you got it fixed though!
t.mcginley.jr
1966 Ford Mustang
Thank God I've never brought my Z to a shop lol $180 labor to change a RELAY? I can't imagine what they would charge to change an injector or something
Peabody
He Charged 2 Hours Labor.
I had everything apart and the fuse box almost out and then I put it all back together before I took it in. I wonder if I could have got a better deal if I left it apart and just let him finish up if I would have got a better deal. If the book said it calls for 2 hours they charge 2 hours even if it takes 1 hour. It is not that hard to take the kick panel off and get to the fuse box. I did not want to go any further because the fuse box would not come out that easy and I thought I would screw something up.
