My CA runs strong, no issues, except the head gasket weeps a little. I have ARP head studs and I didn't read the FSM about them until after I installed. I pulled the head to put a new head gasket and do the ARPs right and this is what I found. I'm not sure if 3 cylinders are running right and one is not getting any spark/fuel or if 1 is sealed properly and the other 3 are dirty from burning oil. What are your thoughts? The static compression is 140 (i have aftermarket cams). It runs fine. Literally the only issue i've had was that the head gasket weeped from the back so I was taking it off to change it. Now I am not going to put it back on until I know what the issue is because I have a LOT of money in this motor and I can't afford to blow it.
Car runs great, there's never any hesitation... so I had no idea anything weird was going on. What do you think is going on?
3 cylinders have carbon and s***, the 4th is pristine. Car runs 13afr idling and 11 afr under boost. It's not fully tuned yet, the weeping head gasket posponed my next dyno session and I've been doing flares and s*** so I haven't been back yet.
head
block
