fredejo »
https://forums.nicoclub.com/fredejo-u24247.html
Tue Jan 11, 2005 9:11 pm
90 s13, got a code 13 on the ecu self diagnostic, (temperature sensor). so i pulled the connector & it was really corroded, cleaned it off . then started the car & put an ohm meter on the 2 connectors on the sensor & it read 1085 ohms. the post i read said it was supposed to be 3 ohms cold & as the engine warmed up it should read .33 ohms. did i check the wrong temp sensor?? it is the red connector that has the same type of connector as an injector right??? & to check it you put the 2 wires from the ohm meter on 1 of each of the 2 prongs on the sensor right???? & yes the ohm meter is working correctly or does that ridiculous reading mean the sensor is bad & im just retarded (i have no idea what a bad reading would be....) ANY INPUT WOULD HELP!
