flinterman2000 wrote:What year is your 720. Mine is an 85 and has an alternator with built in regulator. As a result there is no combination meter, however I have a similar problem with the the high/low beam. In mine it goes to high beam for itself and a little shake of the light switch it goes back to low beam. I do not have a scanner to post the wiring diagram. Sorry.
Just recently fixed this problem, the contacts are dirty and need to be cleaned.
You need to remove the steering wheel covers and remove the wiring connector to the combination switch. You will see the pins on the comb. meter, they are surrounded by a housing that holds the pins in, you need to remove this part. They are held in by two small phillips screws. Carefully unscrew them as time may have made the housing brittle.
Use a scotch brite pad and rubbing alcohol to clean the contacts.
