Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Sun Mar 20, 2005 11:38 am
When you cut the diff off, you do NOT have to weld anything shut. The diff is closed off from the motor oil. Just cut the diff off and the other side output shaft and that is it. You can leave the metal rod in that is on the inside of the pan. That way, you don't have to weld anything shut. Just take a circular piece of metal and JB weld it in the holes to prevent dirt and grime from building up over time....
