WTB: NEED DROPPING RESISTOR! and MAF!
stealthj
i found a harness! i NEED DROPPING RESISTOR! and a MAF if POSSIBHLE!!!
iliketocrash
no one seems to be able to answer this question... would you be able to use a dropping resistor from a DSM?
USDM_OneVia
Car: Racing
I got a MAF now. Just installed my Z32. If you need one, let me know!
Joe
biosehnsucht
for maf, you can wire up a KA24E SOHC MAF, they are slightly larger reportedly but have the same airflow-to-voltage mapping and therefore don't require retune
for dropping resistor, with modifcation, it should be dooable. might even plug and play, hard to tell, with a 1G. saw a pic of one on ebay and it looked almost perfectly identical (even made by JECS w/ a metal bracket) to the stock one..
other options are CA16DE pulsars.. or making your own. need 6 ohms and enough power handling for the injector on each..
fanta
Does anyone have a picture of the dropping resistor? Is it close to the coil packs?
f s t caz
Car: VG30ET D21 Extended Cab Pickup
fanta wrote:Does anyone have a picture of the dropping resistor? Is it close to the coil packs?
and its located over by the MAF/airbox/front left corner of the engine bay
fanta
Much appreciated. I have a few 1G DSM ones and know of quite a number of CA16 Pulsars in the local yards.
stealthj
how much shipped for the MAF USDM onevia shipped to 95014
fanta: how much for the ca16de pulsar MAFs?
fanta
I plan on going to the junkyards tomorrow, will report back on the prices.
stealthj
ok thanks
fanta
MAFs are ~$30.
stealthj
paypal email address?? total with shipping?
fanta
[email protected]Unsure on the shipping, really shouldn't be much. Do you want me to pick up the CA16DE MAF or the KA24E MAF?
stealthj
which ones better
fanta
Not a clue, maybe someone on here may know.
rico05
Car: 1992 RMS13 w/ CA18DET
Not to ruin a sale, but I bought 2 KAE MAFS for $10 each. Also, you will need to rewire the harness for the KAE MAF. Here is how to do it:http://www.nicoclub.com/forums...65531
stealthj
how about the ca16de MAF? do u have to rewire the harness for that?
iliketocrash
when you use the KAE mafs do you have to adjust fuel delivery at all?
rico05
stealthj: IIRC, no. Should just hook up. Look at it, and if it has 3 pins and a adjustment screw, you should be golden.
iliketocrash: No. I have no reason to think that I have any prolems thus far with my KAE MAF.
fanta
rico05 wrote:Not to ruin a sale, but I bought 2 KAE MAFS for $10 each. Also, you will need to rewire the harness for the KAE MAF. Here is how to do it:http://www.nicoclub.com/forums...65531
No worries, every KA I found was either missing the motor or MAF :D. Managed to pick up some 4600cc's from an S4 though.
stealthj
did u find any CA16DE pulsar MAFs?
stealthj
still dont have MAF, still dont have dropping resistor.....
anyone???
biosehnsucht
check those CA16's if you go back for dropping resistors. if they're not direct swap they'll be workable with just some harness rewiring..
stealthj
bump...
i think ill go pick up a KA24E MAF from the junkyards or something, but still need drop resistor!
cuzan0
here's a stock ca18det mafs with resister for only $50.00 buy it now on ebay http://cgi.ebay.com/ebaymotors...33557
stealthj
How do u know it includes the drop resistor?
biosehnsucht
look at the pic! it's still attatched ! hah
if no one else wants it I'll take it lol..
stealthj
too late i also payed for it already :) :)
THANKS EVERYONE, ...(still need 91' KA wire harness....)
biosehnsucht
you'll need a new filter element for that filter but they're not too expensive, then you can pimp your mad tyte JDM HKS filter too
fanta
Green mushroom of death.I do not like those filters at all.
