WTB M35 Mid-Pipe
JDMlove
Car: 2006 M35X
2007 HR 350Z
hi!
i want to buy an after market mid-pipe for my M35X, i prefer the Greddy SP2
If any please tell me
cruzad3r
Car: 2006 Infiniti M35x fully loaded
hey, what did you have to do to the ebay M2 y pipe to make it fit on your m35x?
JDMlove
Car: 2006 M35X
2007 HR 350Z
i ordered 03-06 350z Y pipe, which is a mistake, i had to fabricate 60% of the y-pipe
u can order a 07+ 350z y-pipe and will fit our X with little modifications
cruzad3r
what is this "little modifications" you speak of?
i understand both y pipes are physically different and most noticeably is at the "long" vs "short" neck of the y pipe where it's connecting to the mid pipe. since the X version has the "short" neck, i'm hoping i can just buy the HR version and it'll fit.
can you comment on your "60% modification process" to make this works on your M35x? thanks
JDMlove
Car: 2006 M35X
2007 HR 350Z
ok! for the 03-06 350z Y-PIPE, they Got a long Neck and short 2 pipes! So, i made the Pipes Long, and made the neck short.
The HR Y-Pipe already got a short neck! but am not sure if it will fit our M without or with modifications!
cruzad3r
how much bending did you have to do to the pipe and how bad/good clearance on the car?
JDMlove
Car: 2006 M35X
2007 HR 350Z
the new mid-pipe went exactly in the same place were the original mid-pipe was! so t he clearance is ok!
well, no need for any bending! i cut some pipes and replaced them with others.
My Friend!! if you will get the 350Z HR Y-pipe you wont need to do such modifications!!
COULD someone plz tell me where i can find only Mid-pipe for my M35!!
06M4.5
Car: 2006 M45
Megan Racing
JDMlove
Car: 2006 M35X
2007 HR 350Z
megan mid-pipe sound is too much!
other plzzzzzzz
cruzad3r
there aren't a lot of choices for these cars dude. Greddy, Stillen, Megan, are few names that i can think of. unless you go and do custom piping then you're pretty much in the realm of those guys. I think Greddy sounds really nice because that's what i have :)
Partysan7
Car: 2008 M35
Hey,does anyone know if the megan mid pipe is exactly same sizewise as stock mid.? I currently have magnaflow axleback welded into the stock mid pipes connector and would like to just bolt in the midpipe without touching the mufflers
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
JDMlove wrote:hi!
why not have your exhaust guy make you a Mid-pipe?? should be less expensive compared to paying for it to be shipped to you...
JDMlove wrote:megan mid-pipe sound is too much!
other plzzzzzzz
if you are still running stock mufflers, a bigger mid-pipe won't be beneficial...
can you post a sound clip of your current set up?? I know you installed Berks and a different Ypipe...just curious how your exhaust system sounds and/or performs....
JDMlove
Car: 2006 M35X
2007 HR 350Z
my sound in not much higher than stock!! the tone is little higher, but i have rasp going on :(
cruzad3r
so motordyne also have some exhaust part. but they are not CHEAP :)
mexillis
Car: M45s
Tanabe makes mid pipes for the M and so does fujitsobo. Both won't be cheap. If you think megan mid pipe is loud the you might want to go custom because I think all the ones for the M will be similar in sound.
JDMlove
Car: 2006 M35X
2007 HR 350Z
i dont mind ordering Tanabe or Fujitsubu Mid-pipe!! but they dont sell it alone! i dont want to buy the mufflers with it!!
BTW Tanabe dont do Mid-pipe for the M only Axle Back (Mufflers)
