i am selling my sr for a built ka project i want to sell the sr swap with everything but the mafs. the bottom end has less than 100 miles and the top end has 0 miles, it is all brand new including hks stage2 cams, valve springs, new retainers, greddy ras, new rockers, new stem seals, new valves and header. the engine still needs the timing chain installed, and the t-25 has some light compressor wheel damage and i would recommend replacement. the swap will go with 5spd trans. ecu, harness with all unnecessary plugs removed, and i also have a koyo for an sr if you will give me your ka rad. and a lil' cash. WILL NOT PART OUT FULL SWAP ONLY! make offer for all, will sell CHEAP!
also i would like to buy a complete ka, i want the whole motor set just as you pulled it with harness and ecu engine must be in good running condition, i do not need transmission but if you have the stock 5spd let me know i might get it anyway.
PICK UP PREFERRED WILL NOT SHIP UNLESS BUYER PAYS UP FRONT FOR SWAP AND SHIPPING THAT YOU MUST ARRANGE
Modified by jrb240 at 8:36 AM 6/17/2007
