wtb complete ca block
1SlowCA18DET
i needed it yesterday.
crazymax
Car: 89 coupe
I got one, needs a rebuild though(seller said it either spun a bearing or it started knocking)..I just picked it up for parts but since shipping is a pain ill let it go for real [email protected]
boost_boy
crazymax wrote:I got one, needs a rebuild though(seller said it either spun a bearing or it started knocking)..I just picked it up for parts but since shipping is a pain ill let it go for real [email protected]
Will cost as much as just getting another one to get this back up and running. Very close to $1000 to be the exact.
Dee
1SlowCA18DET
but the weird problem is that im making the same amout of power as i did before probally more since i had a boost leak. i made around 241at the rear wheels, so i have no ****ing clue man, i just may try to use some mccc and see if its just carbon built up around the rings.
boost_boy
1SlowCA18DET wrote:but the weird problem is that im making the same amout of power as i did before probally more since i had a boost leak. i made around 241at the rear wheels, so i have no ****ing clue man, i just may try to use some mccc and see if its just carbon built up around the rings.
Check your plugs to see if they are getting wet. Also, if you suspect your rings are worn, turn the boost down until you're ready to go inside of it and make some changes. I just hate to make you spend $800 on a motor when your current one is not knocking. A little blow-by isn't going to kill anyone (I hope).
Dee
1SlowCA18DET
plugs are fine, car isnt knocking, so i really wishing its just carbon built up around the rings keeping then from fully sealing, also what is the compression suppose to be at when you test it?
crazymax
Car: 89 coupe
boost_boy wrote:Will cost as much as just getting another one to get this back up and running. Very close to $1000 to be the exact.
Dee
Yeah true, best bet is Ill end up rebuilding with better parts..
