damesta wrote:This is a very common problem, if the car is running, its not the cas though. They can go bad but when they do the car won't run from what Ive seen, Ive never seen a case were the cas is actually giving the wrong reading. Heres a list of things Ive seen cause this before:
-timing belt a tooth off-timing belt tension is off-timing belt is worn-marks on pulley are off because of wear-crank gear is off because of wear-cam gears are off because of wear-worn cas key on the exhaust cam
Even though you have to turn it all the way to the right you should be fine, as long as you can get it to 15 degrees and the marks on the pulley are right. I know alot of people, including me that have had to do it that way and it works fine. Ive replaced everything except the exhaust cam and cam gears(including the CAS) and mine still does it.
You haven't seen enough of these engines to know, but those CAS can give you all kind of skewed readings when they are out of calibration. A bad accident can screw them up as well. There are many versions of that CAS and some versions are worse than others and prominent to failure. I kota's case, his cam timing was spot on, so that's all I need to see to conclude it's either the CAS or exhaust cam CAS driver.
Dee
