WTB: Cams, and cam gears
turbo-sil40
Car: 00' Land Rover Discovery, 1990 nissan silvia conversion coupe with CA turbo swap
I want to buy some adjustable cam gears and a set of cams, I would like a set of cams that will give kind of a bab idle, and also work with stock head internals if anyone has some let me know, thanks
turbo-sil40
bump
float_6969
eBay. Tomei is the only company making new stuff for the CA. You can also get your cams re-ground.
HighwayStar22
Car: 2002 RSX Type-S, 1991 240 Hatch
Or you can buy a set of stock cams from me and have them reground.
turbo-sil40
how can i go about regrinding them who can i send them to and what are some good specs to give a rough aggressive sounding idle any help is appreciated. thanks
niswiz
Car: s13 200sx ca18det powered
tomei isn't a bad move. make sure u get the 8.5 or 8.8 mm lift ones though either wise u'll need vlave sprngs etc.
