WTB: Ca18det Harnesses: Engine, Main, and transmission
oversteer180
Car: 1990 Silver 240sx
I need an UNCUT Ca18det Main Harness (ECU Harness), an UNCUT Ca18det Engine Harness, and an UNCUT Ca18det transmission harness. I need these asap. Please do not rape me on the price, i'm a working college student, and this is my only means of transportation.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
oversteer180 wrote:I need an UNCUT Ca18det Main Harness (ECU Harness), an UNCUT Ca18det Engine Harness, and an UNCUT Ca18det transmission harness. I need these asap. Please do not rape me on the price, i'm a working college student, and this is my only means of transportation.
What is the difference between the main harness and engine harness?
Ghost_silvia
Car: 1991 nissan silvia s13
I have the main engine harness but has 1 cut plug. You can use your stock harness to solder it in and be cool. It was used in a 90 240sx I believe, I just used this converted harness pretty much as reference. The ecu plug i was told was made for the ka ca swap, hit me up [email protected], I also live in Tx so shipping should be that much.
oversteer180
so this is the hareness that goes into the motor and into the ecu, and it is a ca?
Ghost_silvia
Yup can take pix if you prefer, just a lil bit of trouble but if you're serious can do.
Ghost_silvia
To clarify it's a CA harness mated to work with a KA swap.
oversteer180
hmm, i dunno. I basically just need all of the uncut harnesses to get my ca18det running and driving in my s13 240sx. I just want something that is uncut or unaltered to begin with. Unless it is already perfectly wired up for an s13. Bump!
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
I have a ca uncut wiring harness if thats what you are looking for. hows 150 sound?
oversteer180
will it come with the dropping resistor? And is taht shipped. Thank you sir, austin
Kouks
Definitely not shipped, that is a low price for an uncut harness, i paid way more, and have been offered slightly higher for it since. whats your zip code....
oversteer180
