biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Sat Oct 16, 2004 12:38 pm
If you have ROMEDITOR or wtf that free Nissan ECU ROM editor is called it has a built in map for the RB20DET already, if you go into the menu (forget which one), then VQ Map replace or something like that, it has options for Z32, CA, SR, RB20, RB26 etc... it will replace the VQ Map with the corresponding VQ Map for the MAF, no other changes needed for the MAF change. If you also changd injectors you'd have to figure what the change in K value (base injector width) should be to scale from XXX cc to XXX cc (i.e. 370 to 450), should just be a percentage difference I'd think (assuming linear flow which is all we can really do), I think for 370 to 450 you'd multiple by 0.822~ IIRC. Stock is 370? Or was it SR is 370? regardless, example stands, if correct math, new K = oldcc/newcc * old K.
