wtb 88 vg30et TPS and ecu will n/a ecu work on ET?
Discuss topics related to the VG and VE series engines.
FoxFire
Car: 90 vg30eT 240SX, s12 vg30e
i posted on the classifieds..but its urgent
last parts in my 240sx swap...
Will the n/a ecu work for the turbo motor temporarily
ill have the writeup soon
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
I wouldn't use an N.A. ecu unless you have some way of tuning it for the larger injectors and increased fuel needs. Dropping the N.A. ecu right in without a tune will cause it to run very, very rich... likely to the point that it would barely run.
I would go ahead and get a turbo ecu, but be sure to get a later model ecu (88-89 only). These are a little more powerful than the early models and can be easily tuned using a romulator, Nistune, or similar.
I would check ebay, http://www.car-part.com, here http://www.z31performance.com/...=5442, and here http://www.z31.com/forum/viewf...1c74f
FoxFire
im putting a big turbo 70 trim compress and 86. on the hot side
with supporting mods
needs to maintain 12-1 max at 14 through 20psi
pig rich will be better then lean for now..i will be running a romulator tuned ecu
im building my 90 240sx for 375whp adjustable with a min of 20psi max boost~440whpthis is my guide http://www.redz31.com/turbofaq/turbo.faq.htm#fuel
mtcookson
1992 Iinfiniti Q45
and much much more
Ahhh... sounds awesome. Definitely need to post up some pictures.
Well... if you do go with the N.A. ecu be sure to still go with an 88-89 as those will be the easiest to tune. I think Jason has that on his site somewhere.
I know going from 180 cc Maxima injectors to 259 cc Z injectors put me around 9:1 or 10:1 if I remember correctly using no corrections. I was just tuning with an S-AFC II at the time so didn't have much control. You might be able to turn down the fuel pressure a little bit if you have an adjustable FPR, this will make up a little bit until you get the romulator going.
FoxFire
i have an n/a ecu out of my 200sx vg30
ill have to try it
ill have a full writeup on it..with tons of pics
mtcookson
1992 Iinfiniti Q45
and much much more
Sounds good, I can't wait to see how it all goes.
Return to “VG30 / VE30 Forum”
