Want to buy the four-cylinder distributor that fires dual spark plugs. The one I need I think is for the 2 L engine.
It needs to be a 1983 to 1984 720 Pick up. The outside diameter where the shaft is must be just under one inch. I will have to do some machining, but it will be installed in a 1931 Model A Ford four cylinder engine with high compression head using dual spark plugs. If you have one to sell or know of a source, please call me directly at 205-532-6602. Thanks Ed
