WTB: 1995 Q45 CD Changer and plastic knobs
brx1
Car: Q45 1995
Hello:
I have a 95 Q, but no CD changer and some little plastic parts broke.
Looking for:
1. the CD changer and mounting hardare from the trunk. Found one locally, without the mounting hardware. It powered up but would not work (Tough to get cartridge to stay in and very tough to remove cartridge once in. Not sure if the CDs even moved out of the cartridge. Had to disconnect the connector cable a few times-not easy.) and got "CD err" message.
2. little plastic radio power knob
3. little plastic part on the steering column that controls the movement of the steering column (up, down and towards, away from driver).
4. I might also be interested in the rear Bose speaker amps. I got a set from a '94 Q, but sound seems off (somewhat muffled and mid heavy) and the capacitors are different. But at least the rear speakers work again.The part number was also different from the 95 Q. (BTW, the seller from GA was wonderful !!) The numbers and arrangement of the caps on the rear amp circuit boards vary from 94 to 95 Q45s. This seems quite odd as I think the head unit in the dashboard is the same. I do not think this has been mentioned on the forums before.
thx
Brian
[email protected]
