Please forgive if this is posted to the incorrect section. I'm new here & having a difficult time navigating around.
I recently purchased a 1986 720 King Cab 2wd.
I'm looking for a few assorted items.
#1 I believe these are listed in the parts fiche as "Seat Belt stay"? This is a metal vertical bracket between the transmission cross member and the floor pan. (there are 2). The bottom end is fastened to the (automatic) trans cross member with a rubber isolator bushing at the fastening bolt. The rubber bushing is completely deteriorated from old oil leaks and the bracket rattles like crazy under the floor. Anyone have a used one with a good rubber bushing?
#2 It appears that the OEM AM/FM radio is caput. Anyone have an good OEM radio (exact match)? the first three push buttons say "FM" on them, the last 2 are plain black.
#3 The multiple plastic slider shade sections in the automatic floor shifter bezel are all broken out. I would like to buy a used floor shifter cover with nice parts in it. Mine are brown, tan or whatever.
#4 I need both front turn signal lens'.
#5 I need a R/R turn signal lens.
I need numerous other small plastic trim items if you have a 720 for part out. Please contact me!
[email protected]
